Swapped my 03 Classic 1500 engine for an 04 Meanstreak 1600. So I went from 2 stators to 1. But everything seems to be fine except no spark. The engine turns over fine but no matter what we try we can't get anything at the plugs.
Starter, lights, signals, brakes, kill switch, all function fine but not sure where else to look. Cleaned up the ground from the battery. Charged the battery the other day and it still reads 13.2. Don't know if it is the IC Igniter(although the other things connected to it seem to function fine), Ignition coils, Throttle Position sensor, pickup coils, stator?
We replaced the stator to check and see if that was the problem. No difference. What are some other common things that I am probably overlooking that can have an impact? Could it be Timing? Or if the marks on the balancing gear and the stator aren't perfectly aligned could that cause it? Went through most of the wiring backtracking but can't find anything out of place....... I am lost at where to look next......
