21 - 30 of 30 Posts
How did you mount the gear indicator? did you used the double adhesive tape and mounted it on the green plate?
Did you drilled the hole for the wire of the gear indicator? how is the routing of the wire going thru the speedo cluster?
I would like to know because i ordered a Gipro and want to do it the same way as 2lucky
"Feels like I'm always stuck in second gear," ok not really, but since we're all "FRIENDS", I thought I would share a recent mod.
Those in the know are aware that I wrote a "How To" on installing a diode kit for LED lighting, inside your Vulcan's instrument cluster. For more on that, go here:
http://www.vulcanforums.com/forums/showthread.php?t=174329
While disassembling the speedo cluster for the diode mod, it was hard not to notice how empty the case is. The electronics inside take up little room, which left me with an idea and room to play...
I have wanted to have a Tach on my bike, but it's an afterthought on the 900, and looks out of place to me. So, while I decide if that's something I really want to do, I figured a gear indicator might be the next best thing.
The Gear Indicator
Due to its size, accuracy, and ease of installation, I decided to use the HealTech Gi Pro. Its a completely sealed unit that measures about 3/4" X 1" and it has a large colored LED display. The unit works right out of the box, no setup required. Simply plug it into the factory Kawasaki diagnostic port, secure the cable and ride!
The Mod
The Gi Pro comes with double sided tape and is designed to be attached anywhere on your bike you can fit it. Nice, but that just wasn't good enough for me. I wanted a clean factory look so, I knew what had to be done!
Mock up:
Mounted location: Sizing up the window on the illumination plate.
Alignment to Speedo face: Ended up falling between 110 and 130mph. I doubt I'll ever catch the needle over there!
Severed: The Gi Pro's harness had to be cut to pass through the weather grommet and maintain the serviceability of the instrument panel. A Delphi weatherpak harness serves as the panel's disconnect.
Test Fit of the assembly: Looks good so far! The needles have to be set with the instrument panel connected to the bike, with the ignition on, to reset the needles to their "zero" locations.
Terrific modification and well executed. I love factory looking mods and I actually have one on order and will replicate what you did. Before seeing this I was purchasing the handlebar mounted gear indicator holder but not anymore...Great job!
Hey Nezmon, Welcome to the forum from North Carolina. Happy you decided to join us. Unfortunately this thread is five years old. Here is a link to all the discussions on this forum about gear indicators. Also a link to Healtech. Thanks again for joining the forum. Be well.
Well it may be 5 years old, but I for one think it deserves a bump. This its awesome work. Very clean mod, thanks for sharing.
Ancient thread, but yet I am facing this thing right know. This is the nicest looking mod variant I have seen so far.
However,the one you use is very expensive. Why choosing this one over the waááy cheaper ones? I mean, itś not exactly rocket science what's happening inside the little black box?
I have see the likes of these for under 15 dollar, so I am just wondering what justifies the extra money?
Hope someone still is follwing this thread ;-)
Thnx
Thnx
I'm thinking the same as you. Kawasaki sells their own expensive version too. I can't see where any one would be different, they only have one function. Here's a YT search result for the indicators, see what you think.
21 - 30 of 30 Posts
