Replacing front sproket. Reverse threads?
5.1K views 16 replies 6 participants last post by  t4kne
#1 ·
I'm just getting started on replacing the front sprocket. I've hammered the bell washer behind it flat. The nut does not want to turn so I wondered before I get into cranking on this nut, is it a reverse thread?
#4 ·
I had to use a 5ft long piece of scaffold pole as a breaker bar when i undid that dam sprocket nut. I had to sit on the bike holding the brake on and rocking the socket and bar, back and forf... then there was a big CRACK... and it was undun...
Its a lot easier if you got access to a impact wrench..
#10 ·
I have the 18-40 combo and love it. First gear is very usable where before I had to go to second almost as soon as the bike started rolling. Now I can idle around in first with just enough momentum to balance. I bought it used with 17-45 on it so it was a huge change to go the other way for me. She takes a little more clutch to start out with and not as quick through the gears as before but now in top gear she lopes along at 70 with ease.
