221 - 240 of 552 Posts
Just got mine dynoed yesterday, made a bit of a difference for the better, thanks to Dave for sending me the map he had but I knew it would not be quite what the bike needed, but it was an excellent start, as it was that map made the bike run a little rich, the new map is for the 2-1 V&H pro pipe with hypercharger and came out pretty good.
Discussion starter · #222 ·
Hello all, I was wondering if anybody would share there map with me? I have a 2009 voyager with vance&hines slip ons and the thunder airkit #51010. PC V 17-033 with fuel and ignition. Thanks a bunch. And is your map for power,fuel economy best of both worlds? Thanks again. mikedirtfan@yahoo.com
I sent you my map.:)
systems
i also have the v/h 2into1 but had flat spot issues and noise changed to the quieter baffles and i think the bike performs much better,still loud under throttle but nice and noty at cruise
standard air intake and management system ,just gets hot when idling for awhile
question is is the pcv better than the other management system
had the pcv on my 900 and loved it
Discussion starter · #225 ·
Thanks to those that sent me there map. Now if I can figure out how to open a pvm file and get some time off to play around with them. Thanks a bunch guys.
You have to save the file to your PC then open it up with the PCV software.
If you need further help just let me know.
Discussion starter · #227 ·
Thanks my pcv should arrive today or tomorrow. I was trying to get ahead of the game. Thanks for the information.
Well if you want to get a head start to see how it all works ot just see the map, just download the latest software (1.0.6.4) from this link and check it out,
http://www.powercommander.com/powercommander/Downloads/powercommander_downloads.aspx?ProdType=PCV
If you are new to the PCV, use the "Help" link at the top of the home page of that program and it will tell you everything.:)
Happy Thanksgiving to David and all the Forum Members
Hi there David I have the Tri-Ovals on my 09 Voyager and my Thunder 91010 kit will be here Monday and then I am going to order the PCV, would you mind sending me a Good all around Map to get me started. Thank you
John Hill
Discussion starter · #229 ·
John Hill
Sure John but I need your email address as this forum doesn't support that file type.:)
Hello all. Well I finally got around to installing my pcv w/Ign today and my thunder airkit. Well I started with the dynojet map just for my pipes,vance and hines slash cut. It was better but wasn't that impressed. Then I installed the map davidsheek sent me and WOW what a difference it pulls verygood from idle to redline. Thanks again for the map. Can't wait to go do alittle riding other than just test runs. MIKEBL AKA Smokey if you wouldnt mind to send me your dyno map again I would appreciate it. I have the maps you sent me but kinda confused myself when I saved and named them thankyou. mikedirtfan@yahoo.com
David I have a Vaquero with twin V&H slash rounds, thunder big air kit have a cobra fi200or on it its junk. I buying a pcv to put on i want great performance, great mpgs and little to no decell poppind and back fireing can you send me a pcv map to help bskz4@frontier.com Thank You B Cope. Anyone else that has V&H twin slash rounds thunder air kit on a vaquero or voyager with the same set up and has a good map let me know also Thanks
Discussion starter · #235 ·
Map sent, good luck. :)
Discussion starter · #237 · (Edited)
Does anyone have knowledge of these mufflers other that what advertizement offer?
Cobra Straight Billet Tip Touring Slip-On Mufflers for 2009-2011 Kawasaki VN1700 Nomad/Voyager/ABS/Vaquero Motorcycles. Are they louder that tri ovals ECT. Thanks gene
gsinclair@mchsi.com
From what I've read in the past threads the tri ovals or not as loud. I have the scallop tips myself and the only difference between mine and the ones you're talking about is just the tips. Now I have made mine even louder than the way they come from cobra. There is a endcap at the forward end of the baffle that I removed on both. Now they are just right for me.:D
PS, you should put your post on a new thread. You will get more responce that way. This thread is for PC maps.
Discussion starter · #239 ·
