98Vulcan - Here's the new thread.
My font pulley nut did actually come loose about a year after I installed it. The nut was bouncing all around inside the case but the pulley was still tight. I've not noticed any visible movement of the front pulley and the nut is secured (again) using red locktite. The noise you described is exactly what mine sounds like.
I'm probably going to remove the pulley tonight and take a look at the splines. If I remember, the pulley was not real easy to put on so I may have my work cut out for me trying to remove it.
Has anyone from Scootworks mentioned anything about the material not being hard enough?
How do you remove/replace the transmission output shaft?
