I bought some blinkers off Amazon for the front and I’ve tried to hook them up. The wiring for the bike isn’t the same as the wiring for the blinkers that I bought the blinkers just show a red positive any black negative wire as the bike has three different wires that run to the connector for the lights I figured out the differences between the wires which ones were positive and negative or ground so I just hardwired them together the grounds are not running to anything though I thought because of that it might be the reason for blowing a fuse but I took the grounds ends put them under a screw on the frame thinking that would give the current somewhere to go but all I did was blow another fuse so I’m completely at a loss if anybody could help me I would really appreciate it
