Can you guys help me diagnose a no-start issue? EN500 LTD, 2006, ~30,000 miles, newer battery.
Bike has been ridden and maintained regularly for 8 years with minimal issues. This season I went to change the fluids as I do every October. Changed the oil and filter, drained and flushed and changed the coolant. The coolant was low, below the lower level in the reserve tank (this has happened before). I noticed while doing the coolant that some of it dribbled down onto the head, possibly into the L spark plug hole? Cleaned up best I could. During this process I started it a few times to warm up, circulate, etc.
It ran just fine when I moved it from the garage to street parking. Next day, went to start it, lights came on, but there’s just a single “click” when I pressed the starter button. Lights dim down low and slowly creep back up. Same no matter how many times I tried it. Figured from starting during maintenance and only short trips to work recently, no longer rides to charge it. So I rolled it back into garage and put it on the Tender for 24 hours. The battery is new as of beginning of summer.
Next day – Tender says it’s 100% charged, but same symptoms. Lights, click, nothing. Lights dim down low and slowly creep back up.
Things on my list to check:
Earlier this season it sat for a few weeks, and a few times after that, it was not running right. Full “choke” had a very low, slow, weak idle and it wouldn’t warm up…but turning it off and restarting usually fixed the issue, as if there was a weak connection or something somewhere. Once something settled into place, it started and ran fine. Just to be sure, I cleaned the carbs (carb cleaner all over the outside, and sprayed into throat while running) and added a can of Seafoam. That seemed to fix the issue. Not sure if this is related, or if battery connection issues could cause that behavior.
Thanks for any ideas!
- Battery connections?
- Pull the plugs and check?
