1 - 5 of 5 Posts
Hi all & Thanks in advance for any help, Trust me I've done some serious searching before posting this thread so either my Google Fuuu is Borked or my info isn't already posted which I find hard to believe.
Electrical stuff is Witchcraft to me :confused:
Bike's a 2001 VN800 Classic
So... I've bought an aftermarket rear/brake & reg light that comes with a Brown a Red & a Black wire coming out the back & some Indicators which have a Green a Red & a Black wire coming out of them, I have No manual so could somebody tell me what wires I connect that comes from my Bike.
I'll do the below so you can copy & paste to make it easier.
Back Light Stop Light & Reg Light
Brown -
Red -
Black -
Indicators
Green -
Red -
Black -
I have a New flasher unit to suit the LED's but I don't have a Test meter so need the help so I don't blow anything.
Thanks again for any help & Thanks to All for the Resource I've read Untold good info from this site already. :cool:
Discussion Starter #2
I kept on searching & my Google Fuuu turned this up off the Kawasaki Forums. I'll leave it here for future Searchers & Thanks go out to MFolks :cool:
Color Codes On Most Kawasaki’s
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light. (Check the wiring in this circuit)
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
Only checked the rear light inn diagram in my clymer manual. Your colors all look right, mostly. At the lights, it shows both turn signal are grey, but the left turns to dark green at the connector.
Thanks Rick :smile2:
Today I will mainly be replacing & relocating my rear light & plate, Changing my indicators to some small LEDs & chopping some metal out my guards, Wish me Luck. :grin2:
Did the rear light/Brake & Reg light & moved the plate & did the rear indicators today, Was a bit of a faff but that easy I'm embarrassed for asking. By the time I'd finished though it was 10 times better than when I started. Will do the fronts over the weekend then start marking some lines for cutting down the mud guards a bit. :cool:
1 - 5 of 5 Posts
