1 - 1 of 1 Posts
I purchased the saddleman solo seat which hurt my back from the angle it put me in, i than put risers on which made it a little better to the point where i can ride my 900 custom se for 2 hours without pain but it still is a little uncomfortable. I than thought maybe the willie and max solo would be better because the seat pan does not shoot up and allows my back a little freedom of movement like the oem seat, by the way i had no problems with the oem seat i just did not like the way it made the bike look. Now i have the willie and max solo which i think will be good on my back but it does not securely fasten in the front latch, the rear latch fastens tightly using the oem bracket from the original seat. The problem is the front of the seat at the front lip that slides under the frame does not fit securely and you can literally move it from side to side about an inch on each side. Anyone else have this problem and if yes how did you fix it?
1 - 1 of 1 Posts
