18k on mine now, nothing other than maintenance stuff like tires, oil, coolant and battery. Bike runs great.
Yes I love all the normal maintenance, so easy to do, oil change, brake pads, break fluid, air filter, spark plugs, oil of course, once you get used to taking off the tank, changing the coolant is a snap to, I don't like the valve job, but that's still easier than changing an air filter on a Honda Goldwing, the air filter took me 8 hours to change on the wing18k on mine now, nothing other than maintenance stuff like tires, oil, coolant and battery. Bike runs great.
Pretty impressive.You may hit 100000 miles with that bike.Thank you for posting.Mine's an '09, now with 59,000 miles on it. I'm on my 4th set of tires now (counting the factory tires it came with) and my 3rd battery. Just regular maintenance, with no major problems other than last fall I was riding home from work and my clutch cable gave out, it was down to a few feeble strands of metal holding it together so I got that replaced. Then a few weeks ago the shifter linkage broke and I had a new part (I think they called it a "knuckle") replaced as well. Kind of wear and tear type stuff. But otherwise is still running smooth!
I'm curious, have you adjusted the valves on the suggested interval?Mine's an '09, now with 59,000 miles on it. I'm on my 4th set of tires now (counting the factory tires it came with) and my 3rd battery. Just regular maintenance, with no major problems other than last fall I was riding home from work and my clutch cable gave out, it was down to a few feeble strands of metal holding it together so I got that replaced. Then a few weeks ago the shifter linkage broke and I had a new part (I think they called it a "knuckle") replaced as well. Kind of wear and tear type stuff. But otherwise is still running smooth!
Wow I would be upset if I lost a stator, I've got twenty thousand on mine, looks like a bigger problem than what I realized from these posts! That's a major isn't it? What was the cost replace, or was your still under warranty?Other than the Stator being replaced around 12K+/- No issues 38K miles, do all my own maint. and all before MOM guide lines.
12-15 oil & filters
4th rear tire
3rd front tire
Stock dunlops 404's (170-80-16 on rear)
steering stem & swing arm bearings and seals looked great.
May change clutch cable soon
Trying to find that perfect tire, I guess. The Pirelli MT-66's did win top honors for longevity, smooth ride and no observable cupping but their soft sidewalls tended to be a little squirrely riding 2 up on the Tail of The Dragon. The Metzler 880's came in second on longevity (about 12,500 miles), ride wasn't quite as soft and did develop some cupping, but they do feel good in the curves. No swagger and stuck to the road like glue. The down side is they're getting hard to find. Metzler is pushing the 888's now. The Metzler 888's are very stable but don't grip as good as the 880's. They're also almost too hard. You feel every pebble in the road. Not sure about mileage or cupping yet. Only time will tell. The Pirelli Night Dragon's had a soft comfortable ride just like the MT-66's and felt good in the curves, but mileage wasn't all that great. Especially since they were priced up in the Metzler price range. Mileage wasn't that great on the Dunlap's either if I remember right. Six or seven thousand was about all I got out of them. And lastly, the Sinko's were pretty bad. Mileage was only four to five thousand, cupping, took more weight to balance, and run-out on the front tire was right on the edge. They did really grip the road though. Of all the tires, I think they were the softest. LOL, you could see rubber left behind just pushing the bike out the garage.
Take this with a grain of salt. It's just one man's opinion.
Spring broke?well I miss spoke on my Custom, yesterday riding 2 up when turning left my kick stand started dragging.
My used 900, had 16 thousand miles on it, when I bought it my kickstand was Dripping a little bit, bought about 5 different Springs from auto parts store, for $5, got the tightest one, and fixed. Works great, had it on there for 3000 miles , nice and tight!well I miss spoke on my Custom, yesterday riding 2 up when turning left my kick stand started dragging.
The output shaft bearing replacement would have cost about $1,700 but the extended warranty covered it.Wow, how much did that repair cost? Engine removed and case split? wow.
Since I paid 3500 for the bike, I would just junk mine and buy another one!, lolThe output shaft bearing replacement would have cost about $1,700 but the extended warranty covered it.Wow, how much did that repair cost? Engine removed and case split? wow.
The stator was however was another story, about $900.
