1 - 2 of 2 Posts
The led bulbs I got from superbright led wont work. Their webcite shows the LEDs smaller than the incandescent but it's not true. The LEDs are longer than incandescent. Can someone post a link of the led amber bulbs they bought that fit as they should.
I remember that from their site a couple of years ago, when I was looking for bulbs for my KVS. And it's the reason I didn't buy from them. If I remember correctly, the stock bulbs are 35mm in length. The max you can fit in the housing, with the lens on is 40mm. And that's with it touching the inside of the lens. So 40mm would definitely be your max length, when searching for bulbs. And even at 40mm, because those LEDs are square on the end and not radius'd back like the stock bulbs, it will still compress the bulb into the socket a small amount.
1 - 2 of 2 Posts
