1 - 7 of 7 Posts
Anyone know what the manual calls for?
Are you running a different weight?
I am about 280 pounds so I wonder if going a little thicker than the book would be better.
Hello Zzman the manual says you should use Showa SS-8 oil , which is SAE 10 and 36.5 [email protected] or an equivalent , about using a heavier oil it sounds logical that it will flow slower thus damping more , but I'm not sure how it will affect the overall ride .
I did 5 weight, but you can also use 10 weight
Heavier oils will slow the damping and rebound, and adding or subtracting oil level (changing the air gap) will effectively change damping progression and bottoming out. Not a deal breaker for a cruiser.
if you feel that yhe front is "too mushy" a heavier oil will stiffen it up. i like the front to be a little more responsive. there is no standard for fork oil wt. one mfg 10 wt may be the same viscosity as another mfg 5 or 15.
i use maxima brand (be sure to use the non-racing line!!) only just because i know their 10 wt is approx showa ss-8. i like maxima 15 wt.
google "fork oil viscosity comparison" several charts should come up that you can use if you want to compare brands and their various viscosities.
i strongly recommend taking the forks off, turning them upside down to drain and pump them to get ALL of the old, acidic oil out. fill w/ a small amount of new oil, pump, and turn over/pump again to get all of the sludge out. i know kawi does not even have it on the maint schedule, but i do this every 2 - 3 yrs.
Yes, I think my is a little mushy. I put on the front brake and can easily compress the shocks.
That is what I was looking for. I want at least a 10 weight and maybe a 15 weight it sounds like.
1 - 7 of 7 Posts
