1 - 14 of 14 Posts
So, a 200/70-15 is a direct replacement on the stock rim?
What does this affect, good or bad? Speed-o readings, ride, control?
The 200 is tad too large for the OEM rim but I haven't heard of any horror stories. I run the Avon Venom and it's taller than the OEM lop. The Venom corrected the speedo errors...until I replaced the speedo bezzle and had to pull the needle off. I've got almost 6k miles on the Venom with no problems and plenty of tread remaining.
How does this affect handling, especially turning, with a much wider tire?
The 200 took a few miles to get used to. The Avon has a more rounded profile the Metz. There's a 1" chicken strip I can't use on the Avon - pegs hit the road. Mine is also lowered 2" in the rear and 1" in the front so ground clearance is reduced.
I believe that 200 is about as big as you can go with out modding. a 240 will fit with a new rim and fender and some clearencing of the swingarm. i just installed a 200 pirelli night dragon on mine and love them it rides much better and is more stable at slow speeds. also being a little taller it brings the rpms down a little as well as cut the speedo error about in half.
I have the metzner ME 880 200 series rear tire and love the handling and comfort, not to mention the look it gives the bike.
JUst a thought--- (you can go Darkside on the rear tire) Wednesday I put on a GENERAL 195/65/15 ---$75 FOR THE TIRE---almost as big as a 200---about 150 miles on it and I'm hooked
I've been looking this tire up on the internet and it looks like it's a car tire, is that right? I'm not sure i'd like that on a bike.
(edit) DOH! After more research, i found that's what the "Dark Side" means. Sorry.
Ok thanks.. Why would you do that?? Its flat.. Unless you have one of those 3 wheelers with 2 wheels up front.. To each their own..
1 - 14 of 14 Posts
