1 - 4 of 4 Posts
I have the shortie pegs fitted and want to move the bars back a bit as well. How do you remove the instrument panel to get at the bolts please. Also what does the Booster plug do ? and where do you get one.
The boost your plug and riches your fuel during acceleration. Google boosterplug it'll take you to the site.
Sent from my Pixel 2 using Tapatalk
Instrument panel is simple remove two Allen head screws in instrument panel cover. Then remove the two underlying bolts that retain the instrument panel. Carefully unplug and/ or move panel out of the way/pad tank, the handlebar bolts should be visible now.
Loosen up throttle/clutch housings before tilting bars. I had mine adjusted where the decel cable cleared the tank by 2-4 inches.
1 - 4 of 4 Posts
