1 - 4 of 4 Posts
I went to jack-up the Bike today, as I had this idea I was going to put a scissor jack under it and jack it up with a piece of wood under the frame. Well, I see now that every part of the frame has something vulnerable sticking-out from underneath it, like the oil pan and such. I have searched the forum, googled-it and still haven't come up with a decision on the best way to jack the thing up. Can one of you pro's give me a suggesting, I'm tired of searching. Will the Cheapo stand at Harbor Freight work - I don't see how a couple of these things work; I guess I would be able to tell once I look at one. I thought about getting a winch and hanging the bitch from the rafters, but someone said they've had problems with their bikes ever since. Please help, the weather finally got nice and I need to face the wind and get this tire changed.
quite a few use the jack you mentioned. I had a similar jack, and it never did set solid on it, under the bottom of the motor, its pretty sturdy there. I once bottomed out on a speed bump hard enough to break a fin off and never did have a leak, that was over 6 years ago. The main thing I would avoid getting the jack under is the kickstand switch.
You can use a twenty dollar bike lift. Be aware the cost of material has gone up since the original post. I use this to clean the chain, check the oil, oil changes, clean spokes etc. Just move it forward or back to raise the wheel you want. FYI use a piece of old rug on the side that will go under the frame.
http://www.nightrider.com/biketech/bikelift.htm
If you add a rear bike stand you can get both the front and rear tires off the ground.
This works with the 800 Classic. On the rear swing arm are two threaded sockets for lack of a better description that you can put 12mm x 1.25 bolt into. I found an inexpensive one on sale that looks similar to the one in this link.
http://www.cyclegear.com/SPEEDMETAL-Rear-Aluminum-Pro-Race-Stand
Good luck.
Ron
05 800 Classic
Thanks so much for the great ideas!!! I will get started gathering materials for the lift build unless I see one I can't refuse at harbor freight. I've been so busy I haven't had time to stop there yet, or answer your replies, but I have more time now. Thanks again!
1 - 4 of 4 Posts
