1 - 7 of 7 Posts
Hi guys I am new Here, I have a Question , does any body have Radio noise when the engine is running, but it sound fine when the engine is off , I have the factory spark plug and wires, I have change the antenna radio cable to a shields cable, re- route the cable , but still have the problem , does any body have an idea?? the Aux ,CB and comm, work fine
Discussion Starter #2
I just find out what was wrong, I have LED head light with fan on it ,that was the problem the fan on the LED light was the problem, change the head light for one with no fan, problem solved now the radio sound good
Thanks for the heads up on this. I was about to order a new LED headlight with a fan. But now will look at an alternative.
just use LED light bulb with no fan on them, they work good they are less money than the one with a fan, you can carry a second one for emergency I always do ;) ebay have one 7" Headlight LED Halo Ring + 4.5" Passing Lamps For Kawasaki Vulcan VN 500 750 I ask the guy and he say it will work on the 1700 Vulcan voyager that is a set, or just go for the LED bulb no fan that work good to and is less money
For some reason the forum says I cant edit because I am over my edit limit for 10 days. It has been months since I edited a post.
Anyway, updating this post, I got the rivco LED headlight replacement which has a fan and I get zero DC fan noise from it. I am very pleased with the light and I have at least 20k miles with it now.
Thank you for the information, that was a problem before, I did change the hole set up to angel eye and it work great and look good ;) (y)
If you have a headlight with a fan that is affecting your radio, you can probably solve it with a ground loop isolator and/or a filter. Could be cheaper than spending the money on another headlight, especially if you can't get your money back on the one with the fan.
1 - 7 of 7 Posts
