1 - 12 of 12 Posts
Bike has been on battery tender for months. Recently have been starting bike to keep everything flowing. Checking battery with meter noticed voltage at startup would slowly rise to 16-17-18 volts in slow increments. Turning on head, turn, brake lights the meter did not move. Then it would fall back to 14-15v. Hooked up a temporary voltmeter (why is this not standard issue on mc?) Restart bike, volt dips to 10v comes immediately 12v then to 13v and almost like heartbeat, rises and falls to 14v then settle in at 13v at idle.
It's the 17-18v and the inconsistency that has me worried. This is all at idle or easy run-up on throttle. Haven't been on the road in a while and getting itchy but don't want to venture very far without confidence in the bike to bring me back.
About two years ago put in a new stator and rectifer. Stator was toast and made a horrifying sound. That sound is not present this time.
Any electrical wizards have any ideas.
Oh, it's '08 900LT about ready to turn 50K.
Two questions:
1. You said "turn on headlight". It does not come on automatically?
2. What is the make and model of your meter?
Post back.
Just out of curiosity:
1. Did you prove out the old reg/rect as bad by testing?
2. Was the old reg/rect OEM?
3. Was the one you just put in OEM?
sfair,
Did not prove out any components. About two years ago changed out the stator. Was livid, after the fact, that such a seemingly easy job was quoted in the neighborhood of $900 from the (s)dealership. So I ordered from Rick's and did the job myself which included changing out the rectifer. While under warranty changed out the rectifier again. In the meantime the OEM unit was on the shelf just in case.
So now running the OEM rectifer.
Don't know if I should be concerned but the Kaw manual states that the voltage should increase (up to 15V being acceptable) as RPM's increase. After starting and at idle the digital voltmeter ($16 - Walmart) reads 14.0v - 14.1v. High beam, brakes and turn at the same time do not seem to affect the meter at highway speeds. This I think would be good since my truck volt gauge does not react to every demand placed on the system.
Unrelated, but read somewhere that temp gauges in most cars are not linear. A lot of people used to think their cars were overheating when they weren't.
Am not absolutely sure on the accuracy of the gauge. From what I can tell most bikes have fragile elec systems. Heated gear is warned against. The 900 manual states not to go over 70 watts additional draw which is not even a pair of driving lights. I don't know why OEM's don't seem to want to include a voltmeter on the dash and install more elec current.
Thanks for the input.
My only concern might be that in the act of replacing the reg/rect, you fixed the problem accidently. A poor connection at the reg/rect could cause the symptoms, as you described, and the fault may or may not return. Did you inspect all connectors for dark areas and discolored or corroded looking pins? If you install the other regulator, does the problem return of overvoltage?
Post back.
sfair,
Pins and connector looked fine. Have not had chance to reinstall old regulator but one would assume that was the culprit. Consider also that I did have to return one of Rick's regulators for replacement some time ago. Perhaps their units are not as stout as OEM.
Read last night, under General Vulcan Talk a very long post between you and Gotrods09. Not sure if that is his correct handle. It was amazing but I did not see a final resolution. Was there one? It is guys like you that make this forum special.
Thanks!!
sfair,
I second this!!! Sfair along with other forum members have helped me with my stator and regulator replacement and fixing my bike in the past...Which helped me understand and learn at the point that I troubleshoot my buddy's Volusia a couple days ago and found a faulty connection at the regulator and bad battery.
Thanks again to all this members that keep helping maintain our bikes healthy and our pockets less empty...:cool:
Rick's is reluctantly going to test out my rectifier and send me a new one even though it past the customary one year warranty. I appreciate their courteous customer service and would buy from them again when in need of anything they sell. But this type unit should have a longer service life than what I have experienced. Glad I kept the OEM rectifer just in case.
Just to throw this in there but; one thing Sfair has taught those of us who have dealt with the fun stator deal with the 900, is you have GOT to TEST EVERY COMPONENT! People chase their tails with this stuff replacing parts based on a noise or a low charging voltage.
If it comes back no fault found, I would check the stator output, check for a short to ground, etc. etc. I would also go ahead and double check the OEM reg/rect you put in. It doesn't take long, and it really is the best policy. A Doctor doesn't do open heart surgery when you've got chest pain, he diagnoses the problem beyond a shadow of a doubt before he ever picks up a scalpel. Treat your bike the same way and you'll save a lot of headaches!
Discussion Starter #12
That is a good point. I know from the past electrical gremlins can be a pain. Seems you have a problem until you go test and everything checks out then the problem arises again out of the blue.
Anyway I am grateful for the courteous customer service so far from Rick's and will wait for further word on the rectifier.
1 - 12 of 12 Posts
