VN800 L-shaped coolant steel pipe under carb is leaking. Where to get O-ring? Dealer or it is standard size? Do I have to remove big chrome cover?
5.5K views 13 replies 6 participants last post by  x01660
#1 · (Edited)
248452
248453
#2 ·
Unclear what year and model bike you have. Some of your posts are in the 800 section and one of them mentions a 97 VN1500. Don’t know if you have to take off the side cover. Manual doesn’t show a clear procedure. Looks like might have to. Don’t want to go bending or forcing that pipe to come out. Perhaps another member who has performed this repair will contribute their opinion. Would definitely use only OEM parts. Nothing is more frustrating that using something from the hardware store and it doesn’t work after reassembly. These O ring seals dry out over time. Would do all of them while doing this repair. If one is leaking, it is only a matter of time before another one let’s go. When installing them, have to put some lubricant on them so they don’t twist when reinstalling the pipe.
