1 - 7 of 7 Posts
i have an engine out of a 96 1500 and heads to a 1500 clasic. i also have the carb for the clasic. just need to get rid of some of this stuff!
year
they are off of a 1996 classic. they are in very good shape. the only reason im not using them is because i have the exhaust that comes out on the left side of the bike.
yes it is the stock carb for a 1996 classic. i have pics if you would like to look at it
15k, its a parts motor, to make it complete you would need the water pump gear, a timing chain gear and a timing chain. New wrist pin clips also for the pistons. it had a spun rod bearing so i bought a crank for it. the problem is that it was a crank out of a classic. the classic has a longer shaft on the stator side. i was going to replace the rotor, stator and cover until i found a classic engine.
what are you looking for?
1 - 7 of 7 Posts
