1 - 10 of 10 Posts
Just keep in mind that the brackets use a key and are keyed to the bike. I'm curious if you find a solution to this.
You order it with the key code for your bike and it comes keyed for your bike.
I don't believe it can be re-keyed. You'll either need a copy of the key from the original owner of the bracket (And use two keys); or you'll need to get used brackets but buy a new backrest (or vice versa; I can't remember which has the key)
Found a pretty decent deal on a kqr backrest. Bought it, went to instal. They sent me the wrong mounting brackets... Come on...
Wild. As far as I'm aware, there is only one KQR backrest; what brackets did they send you? Did you drill the holes in the trim?
Discussion Starter #10
I have not drilled the holes yet. The brackets weren't correct, but they did replace them. Going to drill the holes today. The first brackets did not fit the backrest itself either.
1 - 10 of 10 Posts
