1 - 5 of 5 Posts
My problem ....My wife has a 09 883low sportster.. Low fuel lite come on 1 to 2 min after starting bike and stays on. Even with a full tank . Pulled all fuse,s an checked GOOD... Are there a float in the gas tank, that run,s the low lite.. Thinking it may be stuck if so...
Any Ideal,s :confused:
Lite
Everything is computerized now. Try disconnecting the battery and wait a minute then hook it back up and see if that resets it.
Stuart
I read somewhere on this forum that sulfer gets on a wire in the tank and causes sending unit to stop working. The cure was to run sea foam through a couple tanks o fuel.
+1 neighbors Geezer Glider was doing the same thing, that fixed it. Nesides, it's good to run a little seafoam every now and again. (Love that stuff)
1 - 5 of 5 Posts
