1 - 8 of 8 Posts
i found this info on oil filter cross reference,
NOTE: THIS IS NOT MY RESEARCH IM NOT LIABLE FOR YOU NOT DOING YOURS
you should look into the micron rating for whatever filter you are planing on running
replacement oil filters for KAWASAKI 16097-0004:
http://www.oilfilter-crossreference.com/convert/KAWASAKI/16097-0004
AC-Delco PF2135
AMSOIL EAOM103
ARCTIC CAT 3201-044
ARCTIC CAT 3201-451
AUTOEDGE AL6017A
Baldwin B1400
Baldwin B7285
CARQUEST 85358
CARQUEST 85365
ChampLab PH2876
ChampLab PH7015
ChampLab PH7028
DENSO 115010-5390
Donaldson P502067
EMGO 10-26920
EMGO 10-82230
EMGO 10-82251
Fleetguard LF3925
Fram PH6017A
HASTINGS B7285
HASTINGS LF113
HIFLO HF198
HIFLO HF204
HIFLO HF303
Honda 15400-P0H-305
Honda 15400-P0H-305PE
Honda 15400-PFB-004
Honda 15400-PFB-007
Honda 15400-PFB-014
Honda 15400-PJ7-015
Honda 15400-PLM-A01PE
Honda 15400-PM3-405
Honda 15400-POH-305
Honda 15400-POH-305PE
Honda 15400-ZJI-004
Honda 15400-ZW4-003
Honda 15410-MCJ-000
Honda 15410-MCJ-003
Honda 15410-MCJ-505
Honda 15410-MFJ-D01
Honda 15410-MM5-013
Honda 15410-MM9-003
Honda 15410-MM9-013
Honda 15410-MM9-405
Honda 15410-MT7-003
K & N KN-198
K & N KN-204
K & N KN-303
K & N KN-303C
KAWASAKI 16097-0002
KAWASAKI 16097-0003
KAWASAKI 16097-0004
KAWASAKI 16097-1058
KAWASAKI 16097-1061
KAWASAKI 16097-1063
KAWASAKI 16097-1064
KAWASAKI 16097-1066
KAWASAKI 16097-1067
KAWASAKI 16097-1068
KAWASAKI 16097-1070
KAWASAKI 16097-1072
Kubota 15853-32430
LUBER-FINER PH2876
LUBER-FINER PH7015
LUBER-FINER PH7028
MELROE 6671057
MERCRUISER 35-822626
MERCRUISER 35-822626Q04
MERCRUISER 35-822626Q1
MERCRUISER Q03
MERCURY 35-8222626Q03
MERCURY G590000-G760299
MERCURY G760300-1B226999
MERCURY P086824-P325499
NAPA 1358
NAPA 1365
NAPA PS1358
Nissan 3R0076150M
Parts Master 61358
POLARIS 2520799
POLARIS 2540086
POLARIS 3084963
POLARIS 3089996
Purolator ML16817
Purolator ML16819
ROBIN 2576730111
SIERRA 18-7902
SIERRA 18-7909
SIERRA 18-7910
SIERRA 18-7911
SIERRA 18-7911-1
SIERRA 18-7913
SILVERLINE 21358
STP PH7028
Suzuki 16097-1072
TOHATSU (Marine) 3R0076150M
TRIUMPH MOTORCYCLE T1210200
TRIUMPH MOTORCYCLE T1210444
WARNER PH7015
WESTERBEKE 30220
Wix 51358
Wix 51365
YAMAHA 3FV-13440-00
YAMAHA 3FV-13440-00-00
YAMAHA 3FV-13440-10-00
YAMAHA 5DM-13440-00
YAMAHA 5GH-13440-00
YAMAHA 5GH-13440-00-00
YAMAHA 5GH-13440-10-00
YAMAHA 5GH-13440-20-00
YAMAHA 5GH-13440-50-00
YANMAR 124450-35100
Same for the VN 2000 also
The current filter from Kawasaki is 16097-0008. That 0004 has been obsolete for a while.
The NAPA is PS1358 is the one you want even though a regular 1358 will also work....
The K&N 303 is the one you want. The 303 is black the 303c is chrome and both have the hex bolt end for easier removal.
I have tried several of those in the list as it als fit the last scoot I had for 10 years. I generally use the NAPA PS1358 on the Voyager. I do have about a dozen K&N 303c but I use those on my Yamaha's with exposed oil filters due to the filter relocation kits.
K&N 303? KOOL! I have several of those that I had bought for my Sabre. Money not wasted!
good to know i just did a quick search for the stock cowpie filter
im a WIX guy myself (the WIX, MicroGuard, NAPA Gold) are all the same filter btw, all made by WIX
though i found this interesting about the two WIX filters (51358, 51365)
the burst pressures are different and the bypass pressure has a range on the 51365
WIX-51358
Filter Bypass Relief Valve: Yes
Relief Valve Open (psi): 8 psi
Anti-Drainback Valve: Yes
Smallest Particle Filtered: 21 microns
Maximum Burst Pressure (psi): 265 psi
WIX 51365
Anti-Drainback Valve Included: Yes
Bypass Valve Included: Yes
Micron Rating: 21 Micron
Thread Size: M20-1.50
Burst Pressure (psi): 300 psi
Bypass Valve Pressure (psi): 8 To 11 psi
1 - 8 of 8 Posts
