1 - 3 of 3 Posts
I'm looking at swapping the lenses to the clears that have those leds.
I see these being offered but they have the 2 screw set-up on
the front lens and mine are 1 screw and its on the bottom of the chrome housing
of the unit and not on the lens.
It also doesn't state if these (seen on cruisercustomizing ) if there a dual
circuit ( run/signal ) when placed in the front.
I'm thinking it should since its utilizing the OEM socket.
Anyone ?
Paul
I bought the clear lense covers from clear alternatives.
I bought the turn signal conversion kit from Electrical Connection. I guess I also bought some yellow-amber 1156's, because the yellow-amber lenses only needed a clear bulb.
http://www.electricalconnection.com/other-lighting/tsk-star&sport.htm
I installed the same kit on my VTX1300 years ago. If you go this route, both times I ignored the instructions of fishing the conversion's wires, for the signal's positive wires, through the stalks underneath the fender. I just tapped into the positive wires of the signal right there in the housing.
I installed the kit while I had the rear tire off so there was plenty off work room under the fender.
Herb
Thanks for the feedback Herb.
But if I can't find an all in one kit from one source.
I'll just go to a whole new set-up with new LED turnsignals.
Red single circuit for the rear and dual circuit amber for the front.
Both with clear lenses. Just like your taillight .
Which is on the bling-bling list of things to do for me before riding season starts again.
Paul
1 - 3 of 3 Posts
