1 - 5 of 5 Posts
Ok...yep, I checked the bulbs...both front and rear. It is just the right side sigs that aren't working. Any ideas.....common places where wire might fray...bad flasher unit? I am all ears...and no sigs...on right side...left side works fine.
T
Switch, maybe?
Switch, maybe?
Excellent place to start. Open the switch housing and clean the contacts. The gray wire is the right side turn signal lead coming off of the switch. It's not the flasher since it's in front of the switch and the left side works.
Thanks I'll start at the switch....
Well after a lot of pokin and proddin and stuff, I finally decided to take the tank off to test the wiring. After removing the tank, I saw that the connectors for the combo switch (horn, hi/lo beam and turn indicators) didn't look like it was pushed together all the way. I pulled it apart and then reassembled it and "Voile'" I done got turn sigs. I don't know if the connections were loose or just a bit corroded, and if you sigs stop working. You might want to check here.
T
1 - 5 of 5 Posts
