1 - 2 of 2 Posts
Does anyone know a easy way to get to the turn signal relay on vn2000. book says you have to remove rear shock and ecu unit. i want to install a kisan sm-4 in its place,
wocka, wocka, wocka
EZ as cake.... concrete cake.
A&M, gig 'em! there is no ez way. all that stuff is buried.. deep. underneath the battery box. I had to take that whole assembly apart just to get to this allen screw on the speed pick up sensor just to remove a spacer/washer. It was more work than changing the gears. here are some pix of the beast gizzards. When I get to do some real chop work, all this stuff will be minimalized... as in tossed in the parts bin. out, ponch
1 - 2 of 2 Posts
