1 - 3 of 3 Posts
'97 Classic. Left rear turn signal stopped working. Not the bulb. Voltmeter: Get over 4 volts/2 volts cycling when on. Right side get over 5 volts/1 volt and lights the bulb. Checked wiring visually from signal to rear bracket and under the fender forward - no visible rubbing, etc.
Looking for suggestions, thinking maybe something with the switch?
I got a 99 classic and I had the front left signal stop working ended up tracing it back into the head light and found it had a bad connection to a power wire. I would trace the wire to where it gets power witch should be under the seat. And go from there. Hope that helps and you get it fixed
1 - 3 of 3 Posts
