1 - 7 of 7 Posts
I have a 2006 V2K. My question is does tuner or programmer make that big of a difference on such a big engine? If so what would some recommendation's for this?
I recommend the Cobra FI2000R. I use one and have never had a problem. If you have pipes then you will run lean without one. Engine size has nothing to do with it.
Depends on how much tweaking you want to do. I don't recall the specifics if yours is compatible with Power Commander III or V, but they're most tweakable, AFAIK.
Tweaking as in, do you want to connect it and mess with a couple of trim screws, or connect it to a computer and work out fuel maps?
The former being easier but less precise, the latter having the potential to be more precise at the expense of complexity and fiddly.
1 - 7 of 7 Posts
