1 - 2 of 2 Posts
This is something that has been discussed in great detail on here. It usually happens on start up, especially if the bike has been sitting over the Winter or for an extended amount of time. If it goes away after a couple minutes, then don't get too exited about it. If it don't go away after a couple minutes, pour a small amount of Sea Foam in the oil and run a few miles, then change the oil and filter. If that don't make it stop, you will need to drill the screens on the rocker arms. There is a thread on how to do that in the archives that I remember reading. Try the oil change and post the results and we will try to walk you through it. Good luck!
1 - 2 of 2 Posts
