I was trying to adjust the free play in the throttle cable for the first time and while attempting to loosen the locknut on the bottom cable, the threaded part of the sheath snapped. I found that I could temporarily join the two broken parts screwing them into the lock nut, and the throttle appears to work, but I want to replace that throttle cable.
What brand of cable do you all recommend?
Does the stainless steel/"Platinum" and other sheathing make a difference? or is Vinyl just as good?
I'm seeing quite a range, from cheap cables on ebay to expensive ones with fancy coverings, push and pull sold separately.
I'm assuming I should just go ahead and replace both "push" and "pull" cables while I'm at it.
The bike is 2013 with almost 19K miles.
Thanks!
Thanks!
