1 - 11 of 11 Posts
Hey all. Problem is, both oil and temp lights won't go out on startup. Was warming up one morning and both lights came on. She had set a while(several years) and just run to warmup then shut off. Figured it was thermo since the feul line had cracked and failed, replaced thermo, coolant flows and oil in sight-glass is good. Short in wire harness maybe??? She's an 03 800 classic. Thanks...
Coolant light comes on when the temp gets hot, that might be a wiring problem.
The oil light is a pressure thing, so you need to know if the oil is being pumped with the correct pressure.
Just because you have oil in the slight glass doesn't mean everything is OK.
Take a look here: oil and water temp light stay on
Thanks Doc, will try the filter and oil cap trick. How would one check the oil pressure if there's no guage? And can I add a guage w/o a major mod? Appreciate the quik response!! Ride safe
BTW, ran the bike for a few minits after replacing the thermost, yes I know, a mite risky but she ran fine after warmup, no odd noises other than the mild valve tap the vulcans do... will continue the wire harness strip lookin fr shorts. Thankee sai
LITES OUT!!! Thankee sai Spindog n Doc!!! Gonna take r onna test run t chek evertaing...when its above freezing!! Couple of days maybe. Great team here!! Thanks again all ya'll.
2008 Vulcan 900 Custom, Hard Krome exhaust
What did you find???
CMOS
CMOS, Apparently the thermostat went out, sitting idle/not being stretched out, for many years, maybe 6-8, and she overheated. That overheated the oil, my best guess and the oil system cavitated, there was no oil leakin out on unscrewing the filter. Did that lil trick that Spindoc suggested and the oil system reprimed and ALL IS GOOD. So far... gonna take r onna short run t make sure tommorow... will let all ya'll know how it goes fer sher
Discussion Starter #11
Btw, as I posted elsewhere, when it's cool out, say round 50, and y rev her, as I sometimes do, she'll cavitate. Apparently the passages on this gal are tight, oil and coolant. Boy these japs, no dis intended, I love my Kaw, shore do buildem tight!
1 - 11 of 11 Posts
