1 - 2 of 2 Posts
Question, how much gas will leak from my tank once I remove the tank and disconnect the fuel hose.. Where should I remove it from? The tank or closer to the engine.. Plan on taking it off tomorrow to put on the commander.. Weather hasnt been cooperative so still got about 1/2 tank.. Thanks..
Behind the coil cover on the left side, there is a quick disconnect for the fuel & a wiring connector that will also need to be disconnected. You will only loose a few drops of fuel from that connector.
HTH
Max
1 - 2 of 2 Posts
