1 - 3 of 3 Posts
i have had the tail light fuse blow on me which means no tail brake or speedo light. I took the bike to the dealer and they could not find any short in the wiring i know i am not crazy is there anything else that could cause this?
Has this happened often? Or just once? If just once, then it could just be a bad fuse.
If often, then there is defintely a short or an over load somewhere. Have you done any mods that may be adding load to the tail light circuit? If not, then you need to just find the short. It could be anything from a wire that has vibrated a worn spot to a bad brake light switch, etc.
Brought bike home today out come is a bad socket in the left turn signal causing a short. Need to replace the left front signal assembly.
1 - 3 of 3 Posts
