1 - 4 of 4 Posts
I wired an adapter per instructions, using diodes and resistors, in the correct orientation. Tach had no signal, but backlight worked.
Disconnected one lead from one negative side of coil, tach read half revs. Disconnect that lead, connect the other to the other negative on other coil. Half revs only. Switch leads..... one at a time, on each negative side of each coil.
Half revs. Connect both to each negative side...nothing. I thought I might have a bad diode or resistor, but each side worked by itself, so the current flows through each side.
Any help is appreciated
You solved the problem before I had a chance to tell you what you already know. I had the same problem last spring and made a post then about the reversed schematic at Gadgets website. Too bad I don't know how to contact him to let him know. I hate electronics, I am always blowing fuses when I try to hook anything up.
Silver Fox
1 - 4 of 4 Posts
