1 - 3 of 3 Posts
My 08 LT was running fine. Left work and at 2d lite as I let out clutch the motor wanted to die like low fuel (NOT the case), would rev fine with clutch pulled in but not otherwise. After about 30 seconds like this I was able to slip the clutch and make it home (20 minutes) with no problem but runs a little rough. Starts fine and idles ok. Only have 8k on bike, was service last Nov for the 7.5k and put on battery tender over winter. Have put about 300 miles on it since out of the garage then this happens!:confused:
sounds like maybe injectors a little gumed up run some seaform though the fuel system but first run that winter fuel though it if you all ready have try it does a great job of cleaning up the valves to
1 - 3 of 3 Posts
