1 - 11 of 11 Posts
No, they don't make one yet.:mad: But the customer service guy at K&N said that the more requests they get, the more likely they are to produce one. He gave me a link to place a request for my bike's air filter. I figured I would post it here so we could all bombard them with requests. Who knows? Maybe we will get their attention.:rolleyes:
Http://www.knfilters.com/products_needed/default.aspx
Done. Good idea, Jeep Pirate.
Supposedly, Uni Filter was going to make on for us that would be available in the spring, but i haven't seen one yet.
Done! GREAT idea! Wonder if the BTK folks have this link yet?
EDIT: They do now. :)
K&N said that 2+ years ago. They also said that their filter probably couldn't meet performance expectations so they decided not to build one for the 900. I'll stick with the foam, got a life time supply of it.
Well, I figured I might be a little nieve. But thought it might be worth a try. For the folks who cut up a K&N to glue in the stock bracket, which one did you use? Also, did you have to cut out the entire center plastic rib from the stock bracket? Lastly, when switching to a K&N or foam glued in the stock bracket, did you have to use a fuel processor? I have done stage 2 debaffle.
I think if you open the air intake you'll need the fuel processor. Haven't heard anyone on here say they've done this without one. I used the unifoam, as Baitis did, and have a Cobra fuel processor on mine.
I'm using 60ppi Uni Foam but if you cut up a virgin K&N (not yet oiled) you can use a bead gas resistant silicone sealer. You'll need a fuel processor and more fuel if you also eliminate the secondary throttle plates.
Just heard back from the Uni Filter folks... nothing in the works with them either.
It'd be nice to find a K&N that we could just RTV onto the casing.
1 - 11 of 11 Posts
