1 - 2 of 2 Posts
Ok so I have seen this issue is kind of common, but i am going to bring it up anyway. I replaced my right side control housing, because the old one was damaged; however, when i tried to start the bike, i got nothing. with the key turned, i had lights on my gauges and it is in neutral. I am thinking it might be a faulty wire between the starter switch and the jb. both are new. Now i can get the engine to turn over if i jump the starter directly but I can't get it to fire up either. Any help would be greatly appreciated.
hubbarddanny
Well, if you take the control housing off and jump the kill switch see if that works, if not jump the starter button. Are you sure all your contacts were good when you changed it out. If it worked before it should work again with the new one.
1 - 2 of 2 Posts
