Space between saddle bags and frame
2078 Views 5 Replies 5 Participants Last post by  Superdave54
I'm pretty sure I saw a thread on here that mentioned a product that fills in the large space between the saddle bags and the frame for the Voyager. Any help would be appreciated. Thanks.
Hmmm, haven't heard of that one.
This was just a piece of plastic or maybe fiberglass that was attached between the saddlebags and the frame. Maybe I'm dreaming. It's not a big deal but I'd probably be interested.
You might could get the Vaquero trim piece and alter it to work with our saddlebags.
I extended my rear turn signals and I think it looks better from the back as well as more functional.
There is a photo in my garage. http://www.vulcanforums.com/forums/dto_garage.php?do=viewvehicle&vehicle_id=1357
The Gap
I'm not sure if you are referring to the small gap between the chromed plastic trip piece and the bag on a stock Voyager, or if you have removed your trunk and trim, and now your bag frame is exposed. If it is the latter, like I had on mine, here are the trim pieces I made:
I used the trunk wiring to install the LED strip lights you see. You can also see that I mounted the antenna on the right hand trim piece so I'd miss it when I threw my leg over the seat.
