1 - 2 of 2 Posts
Sometimes a neutral light and sometimes not, because when neutral is off the engine will not start on the side stand, and it is not good because I can not warm up the engine if I do not sit on it, where is the neutral indicator. I'm looking for it in Reparatur book, and I found only speed indicator and the sensor behind the exhaust on the right side and I think it is neutral indicator. Please help me if you know. Now currently I have bridged neutral.
Sorry about my writing. I learned the language before about 20 years.:eek:
Best regards
Dario
light
Fairly easy fix. Go here http://rogueownersgroup.com/article.aspx?article=articles/EuroGears.htm . The third photo down is a close up of the neutral indicator pin. Behind the pin is a little spring , the little spring got weak. Take a small tweezers, pull it out, streatch it a tad, reinstall, problem solved. All you need is the two side cover gaskets and at this time, it's goof to change the anitfreeze
1 - 2 of 2 Posts
