Hi Guys,
As the latest owner of a 92 VN1500 i purchased the bike knowing that there was work to be done!!
The bike is a European import and has 23000 KM on the clock.
The VN starts fine but is blowing smoke from the rear cylinder. I have done a compression test and both cylinders were at 120psi.
Plugs to the rear were black and had build up on them, fronts were fine.
Now to me if the compression's were the same front and rear, then its unlikely to be piston rings so my next thought is valve seals or valve seats on the rear cylinder.
I guess that it is engine out and dig into the root cause.
can anyone advise of any tips or hints and where the best place for gaskets in the UK is?
Quick additional Question.
Any tips on removal of the spark plug holder from the cam side of the head? struggling to locate a 27mm hex key....
Many thanks
Stuart
Many thanks
Stuart
