I changed the 38mm Mikuni to the rear stock carb.
The 38mm was WAY to big and ran fine but too rich. I think it came off a 2-stroke bike.
The stock carb has the stock jetting except for two washers under the needle.
I use the stock choke cable.
It was a little hard to make an idle screw adjuster but that was the only problem.
The stock carb sits in much more and is perfect for leg clearance.
This would be the way to go for those of you wanting to go to a single carb!
Performance is excellent and I think that fuel mileage is a little better.
