1 - 11 of 11 Posts
I have a 2006 Vulcan 900 classic with 36k on the clock. The rear shift lever broke on me while riding home from work. It looks like it had been cracked for quite some time before it finally broke off. I'm just curious, is this a common issue? Or am I just shifting too hard?
I'll take a stand at this. I have not heard that this is a common problem. Having said that, it looks to me like that piece is welded, but that might be a factory weld, I'm not sure. Anyway, that shift lever should be available from Kawasaki, for not too much I would think. The shift link still looks good, except for the end piece, which should also be available from Kawasaki.
Thank you for your responses. I have checked with my local dealer and it is available new for about $47. I was just curious if anyone had this problem before or had heard of it being a common issue. Once again, thank you
Interesting I have a 2006 900 classic bought used. The seller handed me a bag of spare parts - it was the old shift linkage.
I wonder it the heel shift puts more stress on the linkage or maybe the operator mashing the shifter with his/ her heel is the issue.
Anyway I use the toe shift most of the time.
Also too much pressure on the shifter which is more easily possible when using the heel function can bend the internal shifter fork in the engine - not a pleasant prospect to repair since it requires splitting the engine case. After mashing the heel shifter a couple of times and with that prospect in mind I adjusted the shifter mounting on the spline shaft so that it is a toe shifter only (heel part of shifter is below the footboard level).
If I may, cut it off and use the toe only. I have no choice. Size 13 shoes are stepping on the rear shifter all the time. i just asked on an recent post about it. I've never had a heel shifter so Im happy I dont have to keep my heel up
so I have been riding my Vulcan with the rear heel shifer cut off and moving the front shift shaft up to next available position. You want to be gentle with the shifts and not slapping the the lever since you are in a position to really put the hurt on the shaft and you have to lift your foot like the brake side.
I could not be happier. Big difference for big feet
K
1 - 11 of 11 Posts
