1 - 3 of 3 Posts
I have a 2000 Vulcan 1500, one day did not start. The battery ran out. I use my voltmeter to see if the battery was good, but I did not disconnect the battery cables so I think I create a short.:crying2:
I noticed a little smoke coming out of the computer control module (maybe). but since then I have not been able to make it run. Now with a new battery I just hear a clicking noise coming starter relay. I tried to check for all the fuses, all look good. Turn signal work. One other thing is that the headlight do not turn on......any ideas?
Welcome to the forums!
Ask your questions in the 1500 forum where other owners can assist you as not
all read the new intro section.
Please fill in your profile to include your bike/location info and that
is easier using a PC vs the app. This will help others answer questions you may ask knowing what year and model bike you have.
howdy
check n see if your battry ground is clean n tight, might try bypassing the starter relay
Sent from my SAMSUNG-SM-J727AZ using Tapatalk
1 - 3 of 3 Posts
