1 - 2 of 2 Posts
· Registered
Discussion Starter · #1 ·
Currently, the only way to add external audio to your GoPro recordings is with a wired microphone or adding your own audio in post processing with a video editing program. Sena has solved this problem with the introduction of the Sena Bluetooth Audio Pack for GoPro.
Not yet listed on the website, to place an order give MIKE a call at 866.931.6644 ext. 804. Is email more convenient? Send us a message through the forum or write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
Included in the kit is the Sena Bluetooth Audio Pack, a Sena frame case, and audio connector to connect the audio pack to your GoPro. A waterproof housing is sold separately.
What's great about this is that it works with any bluetooth audio device! You do not need to use a Sena communication system in order for this to work. Simply pair your preferred bluetooth device, and you're good to go.
Since there is no longer any wired connection with the Bluetooth wireless connectivity, you can now add your own audio commentary to your video from up to 110 yards away with clear line of sight!
Crystal clear audio via Bluetooth 3.0 technology, the Sena BT Audio Kit offers 3 hours of talk time, 3 days of stand by time, and about 2.5 hours to fully charge.
Wanna get in to video vlogging? What better way than with the Sena BT Audio Pack available from Riders Discount! Tell us what ways you would use this GoPro accessory in a comment below!
· Registered
Discussion Starter · #2 ·
For best performance and clear audio in your new video vlog, we'd recommend keeping the "MIC" switch set to the "OFF" position. This turns off any audio recording from your GoPro's onboard mic and will only record your bluetooth microphone audio to the file. Having the switch to "ON" will record both.
When the Sena Backpack is attached, you can charge both the Sena and GoPro via the Sena's USB port. The backpack will last as long or longer than your GoPro's battery depending on your GoPro video settings.
Any questions or interested in making a purchase? Feel free to post up in the thread below or give MIKE a call to place your order today!
1 - 2 of 2 Posts
