1 - 9 of 9 Posts
I have a 2012 Kawasaki 900 Vulcan Classic. I can not remove the seat. The key operates the ignition and the park light. The lock will not turn when attempting to release the seat latch. I have pressed the seat down above the latch to help relieve pressure on the latch but it will not release. I will damage the key if I turn it any harder. Any ideas to remedy this will be appreciated.
I have a 2012 Kawasaki 900 Vulcan Classic. I can not remove the seat...Any ideas to remedy this will be appreciated.
Welcome, yoUPer...
Try a shot of WD-40 into the key port...apply consistent pressure, turning key left and then right repeatedly in order to work the mechanism loose.
If the bike has been sitting in cold/fridged temperatures...that could be the problem, as well. Safely heat a spare key then insert and twist left and right..(incidently, I had to do this a few weeks ago). Lube mechanism with WD-40 once it pops. It will Displace the Water (hence "WD") from the mechanism preventing the "freezing" which causes this problem.
Let us know the results...
You didn't make that up, now, didja, Buskman? /forums/images/VulcanForums_2015/smilies/tango_face_wink.png
No, my friend...came out one morning after leaving the bike out all night back in the "Ice Age" days we had here earlier to a stuck seat and fork locks..Danggitt!
END OF YEAR BIKE 2018 Winner
Welcome from the Dark Side!
As you can tell, there are plenty of members willing to help a fellow biker out. Even if they need help with their seat...on their bike seat...you know what I mean.
Looking forward to your posts and pics.
Here at VulcanForums.com there is "No Biker Left...(here it comes, folks)...BEHIND!"
:serious:
(Buskman tries to maintain his "serious" poker face)
Seems simple but i struggled for some time before i figured out the key turns ccw. Seems counterintuitive.
1 - 9 of 9 Posts
