1 - 13 of 13 Posts
Got my Scootworks front pulley in the mail this morning. Took less than an hour to install. Pretty easy to do. I'm impressed with the highway feel now. Much smoother. I haven't noticed any loss of power. And my speedo is pretty close to right on now. I wish I'd done this sooner.
I'm planning to order one of these sometime this week. Does it come with installation instructions and how long did it take you to put in?
LOL Mark, need some caffeine this morning? :p
I've been considering doing this too, although I've also considered Myron's rear pulley. Wonder which one would be easier for a complete mechanical rookie?
Probably the front pulley. You don't have to remove the rear wheel...
Yes it was just the front pulley I did. The instructions are pretty clear. I had to go buy one socket, 27mm I believe. Hardest parts were removing the cotter pin on the exhaust side axle nut, and torquing the nut back on the pulley. I had to stand on the rear brake and reach over with the torque wrench to torque the nut. I wasn't sure what the proper method was to tighten the belt so before I started I put a piece of masking tape on the frame near the belt and put a sharpie mark how far I was able to move the belt pushing on it with my finger, then matched the tightness when I did the reinstall. It's not squeaking so I'm happy so far.
I wish I'd done it sooner but I was always worried I'd lose some power when riding two up and pulling the trailer but it looks like the wife's limit is a whopping 30 miles so I guess my long trips will be solo.
I ordered my pulley yesterday and should have it ths coming week. I hope to have it installed by next weekend...:D
I think it's noteworthy that my speedo is about 9.5% high as my odometr is also about 4% high. As the speedo comes down so will the odometer. I'm hoping for a correction point somewhere inbetween the two, but a bit closer to a true odometer reading. (a whole new world of dicussion when changing the odometer reading!!!)...
Moe, how far off was the speedo before, then after? I was thinking of getting the speedohealer to correct it but wouldn't mind a smoother highway ride. I ride at least 82 miles each day, mostly 65-70mph. The Speedo healer is supposed to correct both the speedo and odo. http://www.healtech-electronics.com/
Gibby
Before the speedo was out 10%. When I went through a radar traffic sign at 110kph on the speedo the sign said 100kph. I haven't been back to test it since the scootworks gear was added but when my wife was following me and we checked it was very close.
I have a 170 rear tire instead of the stock 180 and it has seem to fix my speedo issue. My speed matches my GPS exactly.
The pulley is on my to-do list once I wear down my Avon 200. I need to pull the rear wheel anyway since I have some interference between the inner fender splash shield and the 200 tire at pot holes. When I lowered the rear I cut out a lot of the shield but evidently not enough. My speedo is accurate and it was a pain to adjust when I put on the Webslinger bezel - not looking forward to that exercise again.
I don't understand, if your speedo is erring on the optimistic side, going to a smaller tire should make it worse. You would have a smaller circumference hence covering less ground w/ each revolution.
Baitis, what is your shock set on? Thanks for the post, I was thinking of going to the 200. Still would like to know the percentage of change it would produce, guess I could figure out the math. I was thinking of doing the rear pulley, and I know that is about a 6.1% difference, not sure if that would put me over the top w/ both. If your speedo is accurate now what was it like before you put the 200 on and wouldn't you throw it off again adding the pulley?
1 - 13 of 13 Posts
