1 - 9 of 9 Posts
Anyone know why the rear yellow lights on most bikes only come on when using the blinker?
The front are always on which is what I want and makes good since for being more visible especially at night.
If there is no strange law against this my plan is to just buy 2 aftermarket front ones and just install on the rear.
Any advise would be appreciated.
Thanks.
That's just the way they're wired. There's a great thread in wrench heads about making your turn into running lights on the cheap. I used some of the wiring advise when I wired in some aftermarket turn signals that double as running lights.
If you're up for a little sodering, either way would make you more visible from the rear.
The Law in most States is that rear running lights need to be red. Check local Laws in your area. You can change the lenses to red. Some have uses red bulbs with clear lenses.
x2
rear facing always on lights CANNOT be yellow/amber or white. To the best of my knowledge, the only acceptable color for this in all US states is red.
What I did...
Since I bought a light bar with turn signals installed on them, I removed the bulb plug and wiring from the front signal housings and installed them into the rear signal housings, thus making them 3 wire signals. I tied in the new wire into my license plate light so that the bulbs low output filament is always on, just like the fronts, and the turn signals function as normal.
I bought a set of red signal lenses from here:
http://www.customdynamics.com/Kawasaki_motorcycle_clear_tail_light_lens.htm
(I id this with both my 750 and 900. same lenses fit both of the stock turn signals.
My next step for the 900 is to switch to LED bulbs on the turn signals. the ones I want are just a little pricey. I've already got the tail/brake light and License plate bulb LED.
I went to clear lenses and wired in two "X" patterned strips of red SMEDS. With a simple dropping resistor, and grounding the SMEDS through the incandescent yellow lamp I have dimmed red running lights, bright red brake lights and alternating Yellow incandescent/red SMEDs.
Ndr
I added a flasher to my rear brake light for an extra margin of safety but didn't feel it was enough driving in the dark early in the morning, sometimes in the fog.
Recently I added the OEM light bar to my 9 and knowing that the one I took off most likely wouldn't sell you've provided me with an upgrade I was looking for! I'm also going to replace my rear turn signal light sockets with the ones taken from the front and order the red lenses.
Thanks so much for the tip!
Any one know a place where I can just buy the dual light socket?
1 - 9 of 9 Posts
