I am new to this so here I go. Be kind if you have heard this before.
I just bought my 2006 v2k with 37000 on the odo. and there is a noise
in the back. Some say the belt, other's say the bearing. I hope the
first. Any help would be greatly welcomed. Thank's in advance.
It's most likely the drive belt needs to be adjusted. The 2004 and early 2005 models had problems with the single rear hub bearing whereas the 2006 and up models went to a double size bearing so it's not likely it's the bearing on your 2006.
I have a 2005 and when I changed the tire, I noticed that it had two bearings on each side. Is that the double bearing system, has mine been converted?
Nate
