This question is directed to those who have switched all their turns to LEDs or have knowledge about it.
I am in the process of switching over to all LEDs for my front and rear turns on my 2010 900 Custom. I picked up the dual load equalizer to slow down the fast blink rate; however, I came across the "all 4 turns blinking when I press either turn signal" problem. Now, I picked up Kury's diode kit, but their directions are a little vague in the installation procedure. Essentially, I'm supposed to splice into the two wires going into the turn signal indicator bulb with the single-ended side of the diode kit, but then the double-ended side of the kit is supposed to go into the wiring harness for the turns. My question is--am I supposed to bring the double-ended side out of the meter unit and splice into the wires behind the headlight for the front turns? Or does all the wiring for the diode kit stay inside the meter unit? If that's the case I have no idea where that double-end goes considering the only other connections are other indicator lights and the main connection to the speedo. Now, I've been seeing through my research talk of replacing the stock turn signal relay with a solid state one. Would that be an easier alternative solution to the diode kit? I much rather prefer plug-n-play mods over splicing into wires especially when it comes to sensitive electronic components. If anyone has done this mod successfully I would greatly appreciate your feedback since I really do not want to spend more money on halogen turns after buying these LEDs.
