1 - 13 of 13 Posts
Discussion Starter · #1 ·
How many people out there when they store there bikes for the winter put them up on a lift to keep the tires off the ground? I bought a small scissor lift and was thinking of raising my bike off the floor.Could be on the lift around four months I wonder if that's too long?Or would the lift do any damage to the underneath of the bike?
Kawasaki VN800A (1995). Yamaha Raider (2008). Yamaha FZ1 (2006).
IMO, cannot do any damage.
Also there is no need to put on a lift, should be enough if you just move the bike, in order to change the contact spot of the tire to the ground.
Always a good idea. 800's can be a pain to lift. Some of the guys have used a set of hockey pucks to offset the frame/trans clearance problem - works well actually. Another school of thought is to deflate tires to around 10/15 psi for the long sit.
I have a 1600 Classic it sat in the garage without a lift for about a year when i got home and took it out the first time there were no issues except low air. fill the tires up and have taken it out a couple times runs just fine.
Yeah, agreed a lift is not required for most U.S. winters. If you get a nice 45 (or insert your own tolerance here) degree F day in the winter, you can always go for a ride without a bunch of extra work. My 800 has been stored in the shed for about a month but I took it out and rode to work today! If it were on a lift I probably would have taken the truck.
No problem putting 800 on a lift.
I bought a cheap ($129.99 on sale) lift at Sears and it works fine on my 800 Classic. I had to put a 1" X 1" piece of wood under the front lift arm to keep the bike level. I drop ~10# off the tire pressure and push the bike into the corner of the garage for the winter. Been using it for 5 years without any issues. Use a battery tender, top off the gas tank and run some NEW Sta-bil and ethanol treatment through your engine so it will start right up in the spring.
1 - 13 of 13 Posts
