1 - 5 of 5 Posts
Banned
Been lookin high and low no solid answer. 07 vn 900 classic 200 tire front pully will it work and fit yes or no
Hi,
It depends i guess .. i'we been reading alot myself and found some ppl who done this mod with no issues
I did it and had to remove the mud flap behind the tire but i am not sure that i adjusted correctly the belt ..
Wont matter anyway .. the SW front pulley and avon 200 rear def worth doing it
My bike runs alot better now
The 200/70 tire will end up roughly +1/2 inch from the inner fender mudflap.
The Scootworks front pulley will move your rear axle forward just under 1/2 inch.
You be the judge.
I'm going to presume that there are slight differences in the bike assembly tolerances and tire brand diameters that may allow some to run this set-up.
I know it costs more, but the rear pulley will accomplish the same thing and pull the rear axle with a 200/70 tire back to almost stock distance from the inner fender mud guard.
I had the front pulley on mine, and the belt adjustment only moved forward one mark, which isn't much....maybe a couple of mm. Should be fine. I had about an inch or more clearance in front of the tire.
1 - 5 of 5 Posts
